labview stopped at "init tmp resource files" on FC4
hi
any guys here using Fedora Core 4 Linux?
I have installed Labview 7.0 on many Linux distributions successfully. And Labview worked well. But now I found I can't run Labview 7.0 correctly on Fedora Core $.
When I started "labview". the welcome screen was displayed. But it paused at "init tmp resource files". This message is displayed at the right bottom of the welcome picture. And the CPU is used almost 100% by labview.  After about 30 seconds, the labview collapsed - the welcome picture is closed. And no more action.
here is the snapshot
Have any guy here encountered the same problem as me?
 Can anyone give me the suggestions?
帖子被Sheng Bao在05-04-2006 08:50 AM时编辑过了
Forrest Sheng Bao, Ph.D.
Assistant Professor, Dept. of Electrical & Computer Engineering
University of Akron, Akron, OH, USA
https://sites.google.com/site/forrestbao/
(2,960 Views)
Since you are using LabVIEW 7.0 with FC 4 is it likely that you are running into the problem described in the following link.
Why Do I Get Errors When Installing LabVIEW on Mandrake or Fedora Core 2?
Shawn B.
Use NI products on Linux? Come join the NI Linux Users Community
(2,951 Views)
Great, it is ok now.
Thank you very much.
(2,947 Views)
