labview slow speed monitoring! Why?
I make a sin wave by a func-generator and I want to monitor it via DAQ card in Labview. I can see the signal in waveform graph box but when I change the signal's frequency and amplitude it doesn't change quickly in waveform graph! It changes after I stop and restart the program. Actually I have 2 problems:
  1. My waveform graph in Labview doesn't change as quickly as I change input signal.
  2. My waveform graph in Labview just show the first signal I set. After changing signal, the display shows the first signal yet and is slow and fixed in window like a picture! please help me to solve my problem...thanks alot
Message 1 of 12
(3,931 Views)
Can you post the VI?
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 12
(3,928 Views)
Please post your approach.
I assume that you do not update the graph, but write the data only once.
Norbert
Norbert
Expert: Geometry
Message 3 of 12
(3,926 Views)
sure.i attached it.thanks
Message 4 of 12
(3,921 Views)
i press the botton "continious running' so i expect than exactly after changing signal i could see it in my graph in labview.
Norbert
Message 5 of 12
(3,914 Views)
Accepted by Eram
None of the graph elements are inside a loop. So they will be written only once per VI execution.
I didn't look into the code about functionality, but it lacks a profound architecture.....
Norbert
Norbert
Expert: Geometry
Message 6 of 12
(3,910 Views)
oh!yes.thanks.so why my graph doesn't change rapidly even after next execution??
Norbert
Message 7 of 12
(3,903 Views)
Please look into your code and read it by dataflow. You should be able to answer your question yourself when doing so!
Norbert
Expert: Geometry
Message 8 of 12
(3,889 Views)
excuse me what do you mean by ''reading dataflow?'' how can i read it and how it helps me?
now i don't have access to my DAQ CARD to check it.
Message 9 of 12
(3,885 Views)
@Norbert_B
i made changes you noticed and i could see waveform changes now! thnx
but now i have new Question.i have 4-DAG assistant but  just one of them is  ON at the moment.and error cluster of  3others show me this message : "THE FUNCTION IS BUSY" what's wrong with it?
i attach the Vi
Message 10 of 12
(3,831 Views)
