labview singalexpress, language uninstalled, unable to open resouce files
I reinstalled LabVIEW and DAQmx still seeing the same error.
Message 11 of 14
(575 Views)
Hi klni,
Are you using SignalExpress at all? If you don't need it, you might consider uninstalling as an easy way to get rid of the error.
Zach P.
Staff Software Engineer | LabVIEW R&D | National Instruments
Message 12 of 14
(561 Views)
 I don't have signal express installed now, still getting the same error when I am launching programs written in LabView.
Message 13 of 14
(559 Views)
Are you using an executable built in LabVIEW when getting the error? If so, did you copy the lvrt.dll anywhere? This could cause the exe to look for resource files in the wrong place. I'm thinking there is a problem with the executable or your RunTime installation.
Zach P.
Message 14 of 14
(554 Views)
