labview singalexpress, language uninstalled, unable to open resouce files
Whenever I have a programmable DC load connects to my laptop through the USB, labview SignalExpress runs by itself and pops out two windows, one says “language uninstalled" , the other one says" Unable to open resource files"
Message 1 of 14
(3,661 Views)
You can clear device associations by right-clicking on NI Device Monitor in the Windows taskbar. This should keep SignalExpress from running automatically. As for the errors. do you have the language installed that you want to use?
Zach P.
Staff Software Engineer | LabVIEW R&D | National Instruments
Message 2 of 14
(3,651 Views)
Thanks for the reply. My NI softwares are in English , my operating system is running in English as well. Do I have to install any other language separately?
Message 3 of 14
(3,645 Views)
No, you only need to use the languages that your system wants to use or that you want to use. Are you still seeing problems after clearing device associations?
Zach P.
Message 4 of 14
(3,634 Views)
Yes, I experienced the same problem this morning after I turned my laptop on. I don't even see NI Device Monitor in the Windows taskbar anymore.
Message 5 of 14
(3,631 Views)
You may want to make sure NI Device Loader is running, along with the other NI services nearby. This Knowledgebase article explains the process for doing this.
http://digital.ni.com/public.nsf/allkb/0819391CA91B3EB38625731D00024649?OpenDocument
Zach P.
Message 6 of 14
(3,624 Views)
I am still getting "No supported languages installed" and "Unable to open resource files"errors. I don't see NI loader service.See attachment. Thanks
Message 7 of 14
(3,612 Views)
Hi klni,
Can you make sure that NI Device Loader is not in the services list. It will be called "NI Device Loader", not "National Instruments Device Loader". If this is not showing up, you may want to reinstall DAQmx. You can find the latest version here:
http://joule.ni.com/nidu/cds/view/p/id/2933/lang/en
Zach P.
Message 8 of 14
(3,606 Views)
My NI device loader service status is started.
Message 9 of 14
(3,595 Views)
Hi klni,
You can try to manually start NI Device Monitor by going to Programs>>National Instruments>>NI-DAQ>>NI Device Monitor and then set it to Run at Startup.
It sounds like you might be missing certain files in the LabVIEW Run-Time Engine. You might want to try reinstalling LabVIEW (http://digital.ni.com/public.nsf/allkb/FE6B641E86E55AF2862576DE00038001?OpenDocument) and then DAQmx if you still see the error.
Zach P.
Message 10 of 14
(3,583 Views)
