labview program
HI, how can i plot a graph using the values saved in excel sheet
(4,507 Views)
Accepted by topic author shine89
If it is a true Excel worksheet, read data using ActiveX.
Plot data.
(4,502 Views)
Removed
(4,480 Views)
@_Bryan wrote:
Or use read from spreadsheet file.vi under file I/O.
I should note that the Read From Spreadsheet File VI will only work with delimited text files.  An actual xls or xlsx file will not be read by that VI.
(4,476 Views)
I just tested that and removed my comment due to bad info as you were writing that......
(4,474 Views)
It is a very common misconception.  We've been yelling at NI for years upon years about the poor naming of that VI.
If you are dealing with an actual Excel file and need help, there is an Excel Board thread over in the Breakpoint.  Or you could keep the conversation here and I'm sure someone will come along and help.
(4,460 Views)
