labview perform exe file error reporting)
Running the EXE file cause the follow ing error:
          the vi can't be executed . the error can only resolved by using the Labview full development system
How to solve?
This exe file work fine on other computer.
(2,124 Views)
Make sure all dependencies are included in the build, or at least available to the executable. That means: all VIs that are dynamically loaded, dlls (and dlls used by those dlls), etc.
Your main VI should have a broken run button. If you click it, you should get more details on what exactly is missing.
(2,096 Views)
