labview on microcontrolers
I wrote a labview code and I need to program it on a ((non NI)) microcontroler.Is there any way to do it directly or convert my labview code to C++?
(3,092 Views)
There used to be an embedded toolkit for LabVIEW that could convert a VI to C and compile it, but it was limited, expensive, and not that easy to use. I don't think it's still available. There is no other option for automatic conversion of a VI to something that can run on a non-NI microcontroller.
(3,048 Views)
Accepted by topic author .mohamad.mah11
Hello mohammad.mah11,
The product nathand is referring to is the LabVIEW C Code Generator, refer to the product page for more information:
NI LabVIEW C Generator
http://sine.ni.com/nips/cds/view/p/lang/en/nid/209015#productlisting
The 2013 evaluation is also available on this page:
LabVIEW C Generator 2013
https://www.ni.com/en/support/downloads/software-products/download.labview-c-generator-module.html#3...
In my (limited) experience, the biggest challenge with working with the C generator is that the resulting C code is not the easiest to read.  More information on supported functions can be found in the LabVIEW help, I'd definitely give that a read-over and try out the evaluation version if this is something you're interested in. Performance-wise it's pretty good from what I've seen.
Tom L.
(3,012 Views)
I have LabVIEW 2012 Embedded Module for ARM Microcontrollers.is this what U mean ?
(2,974 Views)
That module uses the function exposed in C generator toolkit but then processes that code further to compile it with the included toolchain into object code and link it to an executable for the intended target. I'm not sure how easy it is to get at the intermediate C code. It definiyly wasn't intended to have that intermediate code bee used elsewhere.
Rolf Kalbermatter  My Blog
(2,949 Views)
