labview help
I need update a program which made with labview full system 7.1. I need run it
under Win7 32bit computer. I have a labview 2010 system(basic)which can not
reach all the functions. I got a error message about NI_AALPro.lvlib. I
attached the error message as following.
"The Professional Package Advanced Analysis library is expired or invalidly
licensed. Activate LabVIEW Full Development System, LabVIEW Professional
Development System, LabVIEW Debug Deployment System or LabVIEW Student
Edition on this computer to continue using this product. To purchase this
product, contact National Instruments. If you have already purchased this
product, select Help >> Activate LabVIEW Components to activate this
product."
I need some suggestion from you:
1, Is it possible run labview7.1 under win7 32bit OS?
2,which system should I try to activate based my products and error message? If
it is possible could I get a few weeks license. It will be great help for me to
figure out which system I need to buy or update. If it is possible could you
please sent me the activation code or software download link.I will buy the
necessary system after I figure out which system is best.
(4,257 Views)
I would like get few weeks free activation and try it before I buy it----if I find out the necenssary system.
(4,255 Views)
You posted to the wrong board.
You can download the latest version of LabVIEW. Otherwise, contact your local sales engineer. LabVIEW 7.1 is not supported. It might work and it might not.
(4,236 Views)
Do you mean that I should download lastest labview7.1?
Or should I download lastest labview2014 or labview2015?
(4,225 Views)
The latest version of LabVIEW is 2015. You already have 7.1 but it's not the full development license. Even if the full version of 7.1 was available for download, you almost certainly don't have the permissions to do so unless you contact NI like I suggested. The 2015 evaluation will include the analysis functions you are missing and the length of time it will work should be more than enough to see if your old program will work.
(4,193 Views)
