how to make customized controls resize with pane
hi,
i had customized controls in my vi, and labels in it are not resizing with pane how to resize it with pane
Message 1 of 11
(4,433 Views)
Message 2 of 11
(4,421 Views)
this is not exactly i want, i want to know how to control the size of customized control programatically
Message 3 of 11
(4,409 Views)
Hi Rizwan,
you control the size of your FP element as always: using property nodes of the FP element!
Message 4 of 11
(4,381 Views)
hi,
   normal property node controll only size of the controll but not resize image of the controll.
Message 5 of 11
(4,366 Views)
Hi Gokul,
Yes, that's true. (Are there any "unnormal" property nodes? :D)
You didn't mention images/decals before…
Decals will not be resized with your control, it's by design. When you want to scale such images too, you need to use other techniques!
You could use 2DPictureIndicators and draw any image you like in them. Then you can scale them in any way you like them to scale…
Anyway: the OP asked how to change size of controls - now (s)he knows the answer…
Message 6 of 11
(4,361 Views)
i want image inside control also to be resized
Message 7 of 11
(4,348 Views)
Hi Rizwan,
then you need to use other methods as mentioned before.
When you have fixed scaling steps you could prepare several images and load them into a 2DPictureIndicator…
Message 8 of 11
(4,344 Views)
Have a read through the comments here. It shows how you can make vector buttons that scale when resized.
(blog)
Message 9 of 11
(4,338 Views)
hi
       can u send me VectorSystemButtons VI Labview8.2 support.
Message 10 of 11
(4,301 Views)
