labview front panel
Can anyone say me why my front panel looks bad?
exactly like the image!!!!
Message 1 of 11
(4,134 Views)
Similar things should be in one place.
Know is playing somewhere, boolean is somewhere. Make it like your controls
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 2 of 11
(4,114 Views)
If you say "looks bad", i imagine that you want it to look different. What would that be?
Did you have a "proper" front panel in the past and "suddenly" it changed to something like shown in the screenshot?
Norbert
Norbert
Expert: Geometry
Message 3 of 11
(4,085 Views)
Yes, In my office PC the front panel looks like this screenshot. But in the lab PC the front panel looks like the first screenshot.
The Labview Version is the same in 2 cases Labview 2012
The office PC has win XP 64 bits like OS
The lab PC has Win XP 32 bits like OS
There is any property that I have to change to view the front panel in the lab like in the office?
Thanks.
And regards!!!
Message 4 of 11
(4,059 Views)
I would suspect something with the graphics settings on the bad PC.  Check the Windows settings to see what the resolution is and what the color depth is.
Message 5 of 11
(4,048 Views)
If you make small changes on the lab PC, save that VI and pass it back to the office PC: How does the frontpanel look there?
Are you sure about XP? Is it possible you mean Win7?
Norbert
Norbert
Expert: Geometry
Message 6 of 11
(4,031 Views)
looks like 2 different versions of the same VI to me - knob is in a different place relative to button controls (and button colours are different, but they could just be all pressed in the other state?)
Is the booean actually on the TAB control - or behind it?
the decorations rectangles have been changed/removed on the good VI.
James
CLD; LabVIEW since 8.0, Currently have LabVIEW 2022 SP1 installed
Message 7 of 11
(3,975 Views)
There arent decoration rectangles, this rectangles appeared without modifications between the office PC version  and the lab PC version, the knob is in other place because I moved, but my intention is to show how the "same" frontpanel has 2 different looks depending on with which PC I have opened the program.
So I need to change any front panel properties to see the frontpanel in the lab like I see in the office PC.
Thanks and regards.
Message 8 of 11
(3,923 Views)
Hi RavensFan in the screenshot you can see the resolution and de color depth.
What do you thing about it?
Message 9 of 11
(3,908 Views)
Those setting certainly look good.
Other questions.  What version of LabVIEW are you using?  is this showing up only in a compiled .exe application, or also the development environment?
Occasionally I've see similar things happen before in an .exe I have.  Sometimes just using some of the controls would cause LabVIEW to redraw those controls and things would clear up.  Sometimes shutting down and restarting seemed to fix it.  It always pretty much went away, and I never had an explanation ast to what caused it or what fixed it.  All I know is that the appearance would be similar to having the color depth set at a low number such as 256 colors, even though the screen wasn't.
Message 10 of 11
(3,861 Views)
