labview.exe has generated error
I am using LabVIEW 6.1 in windows 2000. I downloaded the Agilent3499A IVI from the website and configured the driver and everything. When I run the Initialize.vi, I have this following problem.
LabVIEW.exe has generated errors and will be closed by windows. You will need to restart the program. An error log is being created.
Any help will be appreciated. Thanks
(3,055 Views)
What written in error log file? Publish the data here and maybe we can help you.
(3,055 Views)
The ag3499x driver has a very complicated initialization process because of its modular nature. The driver must detect all of the installed modules and then re-configure its data structure, caching and properties dynamically.
While the driver has been tested thoroughly, it is very possible that variations between your system and our sample test system could be the cause of the crash.
Please use the NI-Spy logging utility to record the NI-VISA API calls that occur when you call Initialize. Looking at those calls will help us isolate the problem. Save the log file and then e-mail the following to instrument.driver@ni.com:
  • log file
  • information about your PC (speed, RAM, PCI cards installed)
  • information about your 3499A instrument (m
    odules installed, GPIB or serial?)
  • link or reference to this page
We will use that information to investigate further.
Bankim Tejani
Instrument Driver Group
(3,055 Views)
