labview error
LabVIEW: Null window.
The top-level VI"denproj.vi" was stopped at unknown on the block diagram of "popup.vi"
I am trying to call another vi from the main vi in ​​labview but I get this error.
(1,168 Views)
Without the VI in question attached to your post, the only thing we can do is to Google, something which you could do too, you know.
https://letmegooglethat.com/?q=LabVIEW%3A+NULL+windows
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000001DcZdSAK&l=nl-NL
https://forums.ni.com/t5/LabVIEW/Labview-Null-Window-stopped-at-unknown-on-the-block-diagram/td-p/10...
https://forums.ni.com/t5/LabVIEW/LabVIEW-Null-window-error-in-an-application/td-p/2539028
There are more links in Google that seem relevant, but these should be more than enough already.
Rolf Kalbermatter  My Blog
(1,156 Views)
(1,101 Views)
You got excellent advice already, but this error should not appear in the development environment. We must assume that this is a built application. Is it?
The application builder is typically smart enough not to remove the front panel for any VI that needs to show it, so we must to conclude that your popup.vi is called in an unusual way.  However, the information you provide so far is too sparse to offer specific advice.
(989 Views)
