labview crio dash7
Is it possible to use a cRIO device with labview, using dash7 protocol?
(2,935 Views)
Hi Labviewr,
Yes a cRIO and LabVIEW will be able to communicate with your dash 7 sensors provided you have a module that can receive the wireless Dash 7 comms.  If this device can be communicated with through serial then In-VISA/NI-Serial can be used to communicate with this.  Can you give me more details on how you want to receive the signals?
Matt Surridge
(2,924 Views)
So the crio does not have a dash7 protocol option, as there is a corresponding zigbee module option? So a configuration would be: sensor; dash7 data transmission; device x module; ni crio; labview; data export file?
(2,914 Views)
You are right there is not a Dash7 option on the cRIO.
Hope this helps
Best Regards
Matt Surridge
(2,908 Views)
