labview connection with STM32 via I2C.
its not using any FTDI chip.
so, now im trying python code to communicate with stm32 via waveshare usb to i2c converter to read and write data as we use minicom or putty to check the connection but its not getting connected.
Message 11 of 21
(1,348 Views)
I want to ask how many approaches are available to do the connection between labview and stm32 via I2C?
HELP!
Message 12 of 21
(1,344 Views)
Hi Anup,
please keep related discussion IN ONE THREAD!
Is there a specific reason you wanted to start a new thread despite you already got answers on your problem?
Message 13 of 21
(1,313 Views)
HELP!
Seriously? I would think there are as many as you can think of! That won’t really help you but is a factual answer to your totally open ended question!
Do you expect us to spend hours listing them all for you? We are not here to do your homework.
Rolf Kalbermatter  My Blog
Message 14 of 21
(1,304 Views)
the error im facing is that
1. it reads the data but it still shows timeout exired.
2. timeout expired error and not reading the data.
3. A framing error ocurred during transfer
4. A overrunn error ocurred during trnasfer. A character was not read from hardware before the next character arrived.
help?
Message 15 of 21
(1,313 Views)
I guess you don't send/use termination character correctly.
Qestit Systems
Certified-LabVIEW-Developer
Message 16 of 21
(1,306 Views)
Hi Anup,
is this still the same communication line as in all the questions before?
@AnupSW13 wrote:
help?
  • You didn't cleanup your block diagram so use AutoCleanup!
  • You forgot to implement complete error handling.
  • You seem to forget about appending LF or CR chars with the command message.
  • You don't need to call VISAOpen and ConfigureSerialPort both. Use only ConfigureSerialPort before the VISAClear function!
  • Hide the labels of the functions, we usually know them or use the context help window to read their names. (It just clutters the block diagram.)
Message 17 of 21
(1,298 Views)
is it correct now?
Message 18 of 21
(1,284 Views)
@AnupSW13 wrote:
is it correct now?
How can we know from a picture?
Read this answer and then come back again:
https://forums.ni.com/t5/LabVIEW/Delta-elektronika-VISA-read-in-error/m-p/4409726#M1299458
Message 19 of 21
(1,280 Views)
Hi Anup,
@AnupSW13 wrote:
is it correct now?
You still forgot to use AutoCleanup…
Message 20 of 21
(1,271 Views)
