labview code for flowmeter sensor
Hi all
I am using NI USB 6229 DAQ and Omega FTB-1302 flowmeter sensor.I made the proper wire connection.Now its time to labview coding but i dont know what to do.i am new in labview.Please help
Best regards
(3,920 Views)
Look at some of the DAQmx examples in the Help...Find Examples.   Your sensor most likely outputs a 0-5V or a 4-20mA signal.  You can read those signals into Labview using the examples.  You will probably need to apply a scaling factor to get a meaningful value.
aputman
(3,906 Views)
(3,889 Views)
It was about DAQ connection.This is coding
(3,881 Views)
You've started several threads about flowmeter sensors and how to read them.  Stick with one of them.  You are basically asking the same questions about how to read them.
(3,876 Views)
