labview build .net interop assembly to read tdms
Hi
im trying to build a .net dll to read som tdms data but so far I only get errors
Im using labview 2013
below I poste the output of my .net dll.
Looks like it cannot find tge open tdms vi. Do I need to install some thing apart to get it working.
can see there I a tdms dll c. But I just what to convert a vi I have which reads tdms to a .net dll. Is that possible?
Hope some body can help
Henrik
outputCluster
{TDMS_READ.Output__cluster}
    x: {double[0]}
    y: {double[0]}
status
true
code
8
source
"TDMS Open in REad_test_tdms.vi->REad_test_tdms.vi.ProxyCaller"
x
{int[0]}
y
{double[0]}
(3,012 Views)
File IO error 8 means that there is a permissions problem.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,984 Views)
Thanks for the advise.
I tryed setting the open TDMS VIs operation to "open (read only) and it works now:)
(2,960 Views)
