labview and MS VC++ code
Hi
Thanks for your response. I think the main  problem i will face in this approach is the large no of arrays i am using in my c++ code. I have to initialize all these arrays in labview which may be cumbersome.Second, i am using MIT's fftw3 library for fft process. Will labview recognize all its data types (e.g. fftwf_complex, fftwf_plan etc)?
Thanks again
REGARDS
asim
Message 11 of 13
(730 Views)
Hi Asim,
Are you outputting large arrays from your C++ code to LabVIEW? Or are the results a subset of that?
You should (see here) be able to convert the FFTW datatypes into LabVIEW compatible ones. In a different approach, this forum post talks about using a script to call the function from within LabVIEW.
Hope this helps,
Fred Visser -- SystemLink R&D -- National Instruments
Message 12 of 13
(717 Views)
Hi Fred Thanks for your continuous response. >>Are you outputting large arrays from your C++ code to LabVIEW? Or are the results a subset of that? results are subset of large arrays. Problem is quite a large no of arrays i have to initialize from labview. Currently i am working on two approaches you suggested. Best Regards asim
Message 13 of 13
(703 Views)
