labview and MS VC++ code
Hello all
I want to interface my MS C++ code with LABVIEW graphic displays. What i am doing is that i receive data from NI DAQ cards using C APIs and do  lot of processing on this data.Now i want to display this processed data on labview displays in real time( just like NI DAQ card channels data is displayed on signal express labview real time).
 Kindly help me for this task as I am quite new to LABVIEW
THANKS
Message 1 of 13
(5,294 Views)
I've never done it before, but I would imagine you would build a LV component (shared library).  But beyond that, I don't know.
It's a starting point though.
A
Message 2 of 13
(5,280 Views)
If you are using NI DAQ cards there is probably no reason to deal with the C code unless this processing that you are doing cannot be done in C. You would need to describe what this "processing" is.
When you install DAQmx lots of examples are installed on how to do data acquisition in LabVIEW. You can simply open the Example Finder (Help -> Find Examples) to find them.
Also, please be more specific about what you mean by "real time". "Real time" is a very specific term. If you need "real" "Real Time" then you must use a real-time OS, and Windows is not one of these.
Message 3 of 13
(5,274 Views)
Hi
Yes i am using NI DAQ cards and the processing involves frequency domain beamforming,correlation etc.I have implemented this processing in C++ and i just want to display this processed data on LABVIEW graphics real time.
By real time i think i donot mean "real". Suppose if i am acquiring 200 ms data at a time, i need to process and display this data within 200ms before next 200 ms data is available to me.
THANKS
Message 4 of 13
(5,259 Views)
There may be a few ways to do this, but one way would be to package your C++ code into a DLL (C++ DLL Tutorial), and then use a Call Library Function Node VI to call into that DLL from LabVIEW.
Your LabVIEW program would take the incoming data and display that on native LabVIEW graphs or indicators. To further modularize your code, you could separate your signal processing code from your DAQ code. Then the LabVIEW code could capture and display, while the C++ code could analyze the data.
Hope this helps,
Fred Visser -- SystemLink R&D -- National Instruments
Message 5 of 13
(5,244 Views)
Thanks for reply. I think another possible way is to create LABVIEW dll and use it in my C++ code (I am using LABVIEW professional development system 8.0 with built in application builder). I have done some modifications (e.g. changing while loop with for loop with single iteration) in a example given by NI “Calling a LAbVIEW  built  DLL in C to Acquire, Analyze, and Present Data” to display my processed data.
The only problem I am facing is that whenever the function “present “is called in for loop, whole GUI fluctuates i.e. appear and disappear and I think this behavior is correct according to nature of this function.
But what I need is a GUI which will appear at the start, and after this only displayed data in it changes (just like graphical oscilloscopes).
In other words I want to build oscilloscope (in labview shared dll form) which will take data from my C++ code and display it in continuous mode.
Kindly help me.
THANKS
Message 6 of 13
(5,176 Views)
Hi Asim,
You may have stumbled upon one of the limitations of this approach. This forum discusses using user events to pass data between LabVIEW processes and other processes. That may address your issue, because with events you won't need to call all of the GUI setup code every time you need to refresh the data.
If that doesn't work, I still would recommend using LabVIEW to get and display the data, and your custom C++ code to analyze it.
A third option would be to use Measurement Studio as it has the ability to natively call LabVIEW style graphs directly from code.
Hope this helps,
Message 7 of 13
(5,150 Views)
I'd also reccomend Measurement Studio.  If you really need to use C++ for the processing, and you are good at it, might as well use the Measurement Studio components and keep it all within C++.
http://www.medicollector.com
Message 8 of 13
(5,144 Views)
Hi
Thanks for your kind suggestions. I think it is not as easy as i thought initially. I have to do some hard work for my real time display
>>"If that doesn't work, I still would recommend using LabVIEW to get and display the data, and your custom C++ >>code to analyze it"
 I want to do the same, only thing i need additional is to display proceesed data (processing in c++)  real time (instead of displaying raw data from NI DAQ cards)
>>A third option would be to use Measurement Studio as it has the ability to natively call LabVIEW style graphs >>directly from code.
Problem is that i donot have Measurement studio. Will evaluation version work for my applications?
Best Regards
asim
Message 9 of 13
(5,115 Views)
Hi Asim,
You should be able to build a LabVIEW program that acquires data (using a NI DAQ card), passes that data to your C++ code (compiled into a DLL), and takes the output of that function and displays it within LabVIEW. Did you have a particular issue with this process? This forum discusses the DLL building process.
I'm not entirely sure the limitations of the evaluation version of Measurement Studio, but it's likely similar to the limitations of LabWindows/CVI. Likely, fully functional for 7 days, than with other limitations. Feel free to download the evaluation version and give it a try!
Hope this helps,
Message 10 of 13
(5,064 Views)
