labview and Formula Matlab script
I have Labview 6.1 and Matlab 6i installed in my PC with Windows 2000. Now, the programs using Formula Matlab script don't work anymore.I run the exemples from Labview (help-exemples-comunications)and there is a message:'error 1047 ocurred at failed to send variable to script server in..Possible reasons: the server failed to execute the script sent by Labview. An error message was received'.
Before, I worked with WindowsNT, Labview 5.3 and Matlab 5 and that work very well. In the new versions that doesn't work..Somebody can say me why and give the solution please?
(3,090 Views)
This exact issue has already been seen before, except for the error number, that was 1050. However, I believe it has to do with the same problem, that is, an incompatibilty between LabVIEW 6i and MatLAB 6.1.
In order to solve this issue, you should contact more directly NI, either by email or by phone. The link to contact them is www.ni.com/ask. You tell the person who talks to you from NI to search for document car2J0A33HU.
Aguila.
(3,090 Views)
