I am trying to create a standalone in Labview 6.1
I have a program built with Bridgeview. I want to make an executable of the program to run on a portable computer. I tryed and I am missing some VI which I told the program to generate using all vi's used to write the program. It simply does not work. What am I doing wrong. Are ther a text to describe the procedure properly on how to do this.
(2,739 Views)
_______
Just wanted to make sure you know about the Run-Time System of BridgeVIEW which you need to run any BridgeVIEW application. This Run-Time system includes the BridgeVIEW Engine etc.
Khalid 🙂
_______
(2,739 Views)
Yes I do know. Is it possible to generate an executable with bridgeview. I do not want to install all the development system
(2,739 Views)
______
You don't have to. You just install the RTS and then copy over your application VIs, SCF file(s), and CCDB file(s) and/or LPD files if using them.
Khalid 🙂
______
(2,739 Views)
