labview VISION + webcam + find pattern
Hi all,
I'm making a job with pattern recognition. Unfortunately, I'm doing a first steps and don't understand everything.
I found a video regarding of this question > http://www.youtube.com/watch?v=trgCbKZXyUE - it's what I want to build and extend it then.
The diagram is finished as on the video, but I cannot catch and follow the necessary pattern. It's showing all the current image instead of requested object.
I think it's not a big issue to find out the problem, but I don't have enough skills to locate it.
So, please, if you can, correct the diagram, which you can find in attachment and then I can go on with my goal.
Thank you in advance.
Michael
(2,914 Views)
Hi Michael,
habe you seen that link if you expand the Youtube comment which starts with something Spanish?: "En este ..."
Community: LabVIEW VISION - Busqueda de Patrones - National Instruments
https://decibel.ni.com/content/docs/DOC-31880
Can you make it work if you follow the detailed screenshots shown on the NI community page?
Chris
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
(2,886 Views)
