labview 8.2 llb run with labview 8.5
On the PC I have delete labview 8.2, but I dont find the CD for reinstall. I have a .llb file made with labview 8.2, Can i run it with labview 8.5 or download labview 8.2, I muss install ii rapidelly.
tks
(2,619 Views)
Costello,
you can update the VIs within the LLB to LV 8.5 if they do not have their blockdiagram removed.....
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,617 Views)
How can I update ? When I start the .vi in the lbb he dont found somme .vi located in DAQmx (wrtie.lbb, start task.lbb,...) How can i install this lbb?
thks
(2,610 Views)
Costello,
if you get loading errors when opening one VI from the LLB like you the ones you get, you have missing components.
Since you spoke of DAQmx, i asume that you didn't install NI DAQmx on your machine. You should catch that up.
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,606 Views)
