why do I get this coercion dot?
I have a strict typedef switch-when-released bool button value change event, and the newval property goes straight into a select.
Why the coersion dot?  I also get it when I wire straight from the control terminal to the select.  Pause Button.ctl is in 8.5
Message 1 of 9
(3,917 Views)
You are not the first to ask this question. See here and here.
Message 2 of 9
(3,909 Views)
I think the select is not truly polymorphic and only accepts a boolean or error. So a (strict) typedef is casted into a boolean.
Ton
My LabVIEW Ideas
Message 3 of 9
(3,906 Views)
Thanks, guys.  I had also come to the conclusion that Type Defs include the fact that they're a typedef in their data, but I was wondering if anybody had a more in depth answer about why it's that way.  Either it's altering the data of a boolean to include the typdef flag, which will increase the filesize of a large typedef boolean array, or it's not included, in which case I don't know how LabVIEW can differentiate between typedefs and nons.
Message 4 of 9
(3,903 Views)
@JeffOverton wrote:
[...] boolean to include the typdef flag, which will increase the filesize of a large typedef boolean array, [...]
Not neccessarily. Boolean has 1 Byte for in information which can be stored in a sinlge bit. So there is plenty of space left to store infos without enlarging the whole data.
But: i am not sure if it works like this, so don't count on it.... (so maybe you are correct....)
Norbert
Norbert
Expert: Geometry
Message 5 of 9
(3,895 Views)
Yeah, I'm just guessing here, and I don't have any giant boolean arrays, so this is more for curiosity's sake.
Message 6 of 9
(3,889 Views)
Norbert I so hope you are wrong, The boolean True value is defined as '>0', so storing any info in the actual data will make all values true.
The typdef info is stored in the data-information about the pointer.
Ton
My LabVIEW Ideas
Message 7 of 9
(3,887 Views)
That could be true as well. And if so, the size wouldn't increase too much either since the array has to contain elements of a single type so all elements share the type. So, in conclussion, the type has to be defined only once.
And regarding my "assumption": Well, it could be encapsulated in the boolean functions and work like masking the "boolean byte". So maybe one bit is not considered for the "!=0" decision....
just some thougths....
Norbert
Norbert
Expert: Geometry
Message 8 of 9
(3,881 Views)
It could even just be a flag bit that's stored at the end of the variable name dataspace.
Message 9 of 9
(3,873 Views)
