labview 2010 installation fails
I am trying to install LV2010 but all my attempts have failed so far. I installed it -> reboot -> the error message came "The installation of this application may be corrupt" [or something very similar]. I couldn't even run the License manager or any sort of NI softwares because the same error message popped up. Then I deleted the complete National Instruments folder from the Program Files, stopped all NI services in the Control Panel - Administration tools and rebooted the computer.
After all that I tried to reinstall LV2010 but I got the error message during the installation that at first "Labview 2010 must be installed" [or something very similar]. At one software component the installer told me that "Labview 8.6 must be installed"...
Does somebody have an idea how to proceed?
The OS is Vista.
Krivan
(3,218 Views)
Have you started the setup process with administrative rights ( right click --> run as administrator ) ?
(3,192 Views)
Hi Krivan,
It sounds like you need to clean up your registry.
Give this link a lookover. If it doesn't help please post back.
http://digital.ni.com/public.nsf/allkb/8703592D07C91AD586256B44000248C6?OpenDocument
Best Regards,
Chris
National Instruments - Tech Support
(3,188 Views)
On my computer I am the administrator.
(3,187 Views)
To be logged in as an admin isn't good enough for VISTA. You should try to explicitly start the setup via the context menu.
(3,179 Views)
Also what you may want to try is copying the disc to your hard drive and install from there. I have found that, that will work sometimes when all else fails. With vista, you are also going to have to babysit the thing to make sure a permissions dialog is being "allowed".
(3,169 Views)
