labVIEW FPGA
     I have a doubt with timed loop....in our project ,at  the  output  of pi/4 dqpsk modulation, the frequency should be 18khz....but in the timed loop block, the internal clock (timing source)is 1khz and 1mhz... and we purchased NI h/w with the FPGA, NI PCI 5640R...Is there any provision in the FPGA to change the clock to 18khz???
(2,890 Views)
you have posted same question in all the forum. stick to a single post.
(2,877 Views)
Hi Sumsum,
I'm not exactly sure what your doing with your modulation but if I understand your question correctly you are wanting to slow down the rate that the single cycle timed loop is executing.  You can simply use a loop timer to do this or you could decimate the timed loop rate.  The loop timer would be the easiest way to do this, you just put a timer in the loop and tell it how long to wait before executing.  To decimate the loop rate you will need to use a shift register and case structure inside your timed loop.  There is an example of this in the knowledgebase linked here.  This knowledgebase deals with a separate issue but shows how to decimate the loop rate as part of the solution.
Stephen S.
1 Test is worth 1000 expert opinions
(2,834 Views)
