keycontrol problem
I got the keycontrol code from
https://decibel.ni.com/content/blogs/MechRobotics/2010/04/14/teleoperate-the-starter-kit-from-20-flo...
when I try to transfer the code to dani it show this error
Deploying Intialize Keyboard.viIntialize Keyboard.vi loaded with errors on the target and was closed.
LabVIEW:  Failed to load shared library lvinput.*:openDevice:C. Ensure that the library is present on the RT target. Use MAX to install NI software or FTP to transfer custom libraries to the RT target.
Deployment completed with errors
Is anyone can help me please?
(5,188 Views)
Accepted by Saik
The key control VI is meant to be run from your computer, not DaNI.  As you use your keyboard on your computer, the key control VI captures the input, converts it to a meaningful robot command, and then sends that command over the network to the DaNI robot.
The error you are getting is because the device input capture VIs are not designed to run on RT, but on your desktop.
You'll want to deploy: Starter Kit Remote Receiver.vi to DaNI and then just run Key Control from your computer.
-Karl
(3,075 Views)
