keybord trick to insert quickly a value into a constant array
Hi everybody,
I want just to know if there is a keybaord trick which allows yuo to pass quickly from an element to the next one (or to new one) while I'm typing the values into a constant array, you know if is there?
What I mean is a keybord key as the TAB key that quickly allow you to pass from a cell to the next one into the grid control.
Thank you in advance,
Regards.
Ricky
Italian Developer engineer
www.www.selt-sistemi.com
Message 1 of 8
(4,110 Views)
Accepted by topic author g_Ricky
Cross-posted here.
Possible solution here, if you're a Quick-Dropper.  Type your stuff into Excel, copy the array and use this QD plugin.
Jim
Message 2 of 8
(4,087 Views)
First of all, thank you for you prompt reply. I downloded both the version of the software you're suggest me but how do they work? How do I have to intall them into my PC?
Ricky
Message 3 of 8
(4,073 Views)
Darin.K wrote:
[...] unzip the files and put them in the directory
[LabVIEW ####]\resource\dialog\QuickDrop\plugins
Create some cells in Excel (or other similar program), select and copy to the clipboard.  (Any tab delimited data will work).  On the FP Ctrl-Space Ctrl-e creates a control with the data in numeric form (simple check to decide DBL or I32).  Ctrl-Space Ctrl-E (shift+e) creates a string control.  Similar commands for the BD to create array constants (numbers or string).  Single rows or columns become 1D arrays, otherwise you get 2D array controls/constants.  Change the letter by renaming e.vi if you'd like.  I chose e for Excel since X was taken along with s for spreadsheet and a for array.
Jim
Message 4 of 8
(4,068 Views)
It seems to work very well, but do you also know how work the second tools (darin.k_lib_import_data-1.0.1.1.vip 72 KB)? Do I have to install it in the same way?
Ricky
Message 5 of 8
(4,060 Views)
You only need that if you prefer to use JKI's Right Click Framework.  If Quick-Drop satisfies your requirements you can ignore the second one.
Jim
Message 6 of 8
(4,058 Views)
Thank you for your interest in this matter. I tryed to install the JKI's Right Click Framework but it need a license and I do not want to buy it.
Thanks again for your free solution!
Ricky
Message 7 of 8
(4,049 Views)
The RCF is free, as is the VIPM that you need to install it.  The license you can buy would be for VIPM Professional, which you don't need for this.
I'm glad this works for you.  There are a lot of QD and RCF plugins available to do a plethora of useful automation tasks.
Jim
Message 8 of 8
(4,039 Views)
