kepware opc server
How can I configure KEPware OPC Server with Labview 7.1 or Labview 8.5 DSC.
I would appriciate, if you guys give the information link or tutorial link.
(7,959 Views)
Do you want to actually modify the settings inside kepware, or just make it work with labview dsc module??
(7,939 Views)
Just want to work with Labview.
(7,842 Views)
I haven't done this with version 8.5 yet. It will use the shared variable to link to an OPC server.
http://search.ni.com/nisearch/main/p/sb/navsRel?q=shared+variable+dsc+&x=16&y=5
Version 7.1 uses the tag engine to connect with an opc server.
The two labview versions use different methods to talk with an opc server.
Which labview version do you really want to use??
(7,830 Views)
Thanks for the info.
(7,613 Views)
Are you by any chance trying to bridge data from Labview into OSI's PI system using kepware?
(6,502 Views)
