keep moving a text like marquee display
How can I continously move a text inside a diplay. It is like a marquee display where the same text keeps moving continously.If somebody has a solution, please save them in version 6.0 and send it across.
(7,348 Views)
Hello, hema!
Do You still need "marque display"?
Here it is: marque.vi
Alexei Bluvshtein a.k.a. ProximaBleu
(7,348 Views)
How do you make the text scroll the other way? Also, how can I increase the speed even more? I changed the 20 to a 1, but would like the text to move faster.
(6,192 Views)
never mind. i have figured out the issues.
(6,186 Views)
Well you found a 15 year old thread (!!) and that old example seems overly complicated.
Here's probably all you need:
To speed it up further, multiply [i] by a small integer. To make it run right-to-left, just negate [i] (or multiply by a negative integer).
(6,175 Views)
This is exactly why I suggested NI lock old threads after a certain time period.
A new question on a similar issue can always reference the closed thread.
=== Engineer Ambiguously ===
(6,155 Views)
Thank you for the example, i found it very useful.
regards.
Domingo Ramirez
Caracas, Venezuela
(6,072 Views)
