is it possible to create a dynamic dispatch VI from parent VI as a template
Hi all,
I'm new to LVOOP and wondering if it's possible to create a dynamic dispatch VI from the parent VI as a template.
For example:
I've got a Class-method in the parent class. All child-classes use this method except of one child, which needs a little tweak on this VI.
So I need to overload the VI in the child class.
When I choose "New -> New Dynamic Dispatch VI" I get an VI based on a template
(As described by Darren Nattinger here: http://forums.ni.com/t5/LabVIEW/Darren-s-Weekly-Nugget-07-07-2010/m-p/1172483/highlight/true#M510414 )
Is it possible to get a copy of the parent VI instead that I can tweak ?
Thanks you in advance!
Balze
Message 1 of 12
(4,103 Views)
Balze,
if you create a vi for dynamic dispatch in your parent class, you can select New>>VI for Override. This template calls the dynamic dispatch VI from the parent class. So if you simply want to add functionality (imho classic usage for overloading), this is the way to go.
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 2 of 12
(4,102 Views)
Thanks Norbert,
I found this way to create dynamic dispatch VIs before.
But that only generates a wrapper around the parents VI.
As you mentioned: To add something before or afterwards the execution of the parent VI that's the way to go.
But that doesn't help me with my problem to tweak the parent VI.
Thanks anyway !!
Balze
Message 3 of 12
(4,099 Views)
There's no way to do it that I know, but I would love one, maybe put up a product suggestion?
Message 4 of 12
(4,075 Views)
I would just do a "Save As" on the parent, then move it to the child class and rename as the same as the parent.
Of course it also easy enough to just drag the parent code into the child and mod as required.
Ben
Message 5 of 12
(4,071 Views)
will doing a save-as create it as an override vi?  I had problems with that before... (I thought)
Message 6 of 12
(4,068 Views)
@ Briota: Let's see if even more users would like to have this feature and then put up a product suggestion.
@ Ben: I tried the "save as" method several times and again and again ran into problems.
Could you please explain your "way" more detailed that i can follow it exactly ?
The drag code int new created dynamic dispatch VI is the way I currently use.You're right, it's easy enough.
I just thougt I missed something because this way to create child methods seems so obvious for me.
Thanks.
Best regards
Balze
Message 7 of 12
(4,066 Views)
An over-ride VI is not that special.
The input and output classe must be "Dynamic".
The icon connectors have to be the same.
The Over-ride VI must have the same name as the parent and be a member of the child class.
So Save-as add to project but not to class.
Move to child class.
Rename.
Ben
Message 8 of 12
(4,062 Views)
Rename.
And then manually change In and Out Terminal to Child Class, right?
Balze
Message 9 of 12
(4,051 Views)
Pointing out my mistakes always earns Kudoes!
Good catch.
Ben
Message 10 of 12
(4,049 Views)
