is double precision float point supported in Labview 2012
  when i used Xilinx COREGEN Float point multiplier (which is supposed to support double float point precision), and try to creat control on 1 operand only SGL appear,
  is double precision float point supported within Labview 2012.?
SA
Message 1 of 13
(3,506 Views)
Hi saketa,
LabVIEW supports DBL as long as I can think of.
But you seem to ask for the FPGA module (while not saying so): this one only supports SGL…
You might want to read this white paper!
Message 2 of 13
(3,498 Views)
  Thank you.
  i think that SGL can support real number like 230.54458884
 am i right?
SA
Message 3 of 13
(3,476 Views)
LabVIEW FPGA only supports Single Precision Floating Points.  But be sure to put this in as a suggestion in the LabVIEW FPGA Idea Exchange.
GCentral
Message 4 of 13
(3,475 Views)
Hi saketa,
no, you're wrong.
SGL has limited precision and will change your number to 230.5445861816406 when you try to input it in a control/constant…
Message 5 of 13
(3,470 Views)
Hi GerdW,
 I do not perfectly understand your answer,
so it increase the precision from   230.544588 to 230.5445861816406
SA
Message 6 of 13
(3,460 Views)
Hi saketa,
no I only increased the number of visible digits. That's completely different from precision…
Create a SGL control/constant in LabVIEW. Type in your number. Change number of visible digits in the control properties to 17+. See what happens…
Message 7 of 13
(3,457 Views)
@saketa wrote:
  Thank you.
 am i right?
SA
Almost, a SGL has 7 decimals precision, so the ending ...84 will be ...8.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 13
(3,453 Views)
Hi Yamaeda,
you need to count all digits of mantissa regardless of exponent, so the cut will be after "45"…
Btw. SGL only has 6.9 decimal digits! 😄
Message 9 of 13
(3,450 Views)
@GerdW wrote:
Hi Yamaeda,
Right, forgot about that. 🙂
My point was ofcourse that a SGL supports a real, as he asked for, but with limited precision.
/Y
Qestit Systems
Message 10 of 13
(3,447 Views)
