iotech multiscan
Has anyone worked with an IOTech Multiscan device in LV?
Any words of wisdom or hints or insight would be very helpful.
I do not know the exact model or any additional info other than I will be seeing one tomorow.
Thank you!
Ben
PS I cross posted this Q to the Multifunction DAQ forum as well.
(3,399 Views)
Please ignore.
Problem solved.
Ben
(3,372 Views)
Just in case some poor soul attempts to use an IOTech Multi-Scan 1200 sometime in the future....
This project turned into a nightmare. I will summarize some of my findings just to save you some headaches.
1) The example was written for LV 4.1 and needed updated to VISA.
2) Cross-linking of VI between the example and VI.lib.
3) Example only works fro less than 48 channels after that the Multi-Scan will never assert the "Scan" bit indicating readings are waiting in the buffer.
4) Wait 5 seconds after doing a reset.
5) Wait 1 second after configuring a channel.
6) Sample rate is limited by channel count!
Hopefully you will not be bit by any of the above.
Ben
bar@dsautomation.com
(3,334 Views)
