interfacing labview with arduino
no arduino is not receive the data and in labview i am not getting any error
Message 11 of 20
(1,615 Views)
thanks Gerdw KNIGHT OF IN
now  my task is almost  working but still one problem is there my labview is not reciving data from arduino it take some default value that 0th index value it increament and sending to labview
Message 12 of 20
(1,604 Views)
Ni nidhi,
do you remember message #2 and #3?
It's still valid! (I guess for the next year…)
Message 13 of 20
(1,598 Views)
sorry,i am not getting you i guess u want  old vesrsion vi?
so i attatched  old version vi
Message 14 of 20
(1,594 Views)
Hi nidhi,
re-read message #2. Don't forget to read my signature line…
Message 15 of 20
(1,589 Views)
Hi nidhi,
Is there an error after VISARead?
What have you set as "byte count" to read?
When VISARead is not outputting any data then you should get
- an error because there was nothing received by the serial port within the timeout
- a warning because you wired a zero to the byte count input
Who is "it"?
Which default value is taken?
Where do you see that "default value"?
Because of that "Increment Array Element" mallable VI in your loop!?
So "LabVIEW" (aka "your VI") is receiving some data?
Do you have problems with your VI - or with your Arduino code?
Message 16 of 20
(1,587 Views)
no any error is there only labview is not able to recieving the data from arduino
Message 17 of 20
(1,575 Views)
Accepted by nidhi11
Hi nidhi,
When LabVIEW is not able to receive any data you will get an error!
So again: any error after VISARead? Did you use a probe or an additional error indicator after VISARead?
Message 18 of 20
(1,571 Views)
sorry but not error comming ok is there on visa error termination and array is taking and array is automatically taking any number like garbage i am not providing that one this is the big problem labview is send the but it is not reciving
Message 19 of 20
(1,563 Views)
Please use punctuation and capitalization in your messages.  That message is just one run-on sentence that I can't understand what you just said.
Message 20 of 20
(1,558 Views)
