interfacing between labview and microcontroller using rs 232
hi my task is to generate a wavefrom of certain frequency and certain duty cycle in labview and feed it to pic18f452 microcontroller and the o/p of microcontroller when connected to CRO should display the same frequency and duty cycle which was fed from labview.
for that when i am sending decimal data from labview microcontrolle is receiving ascii data for eg 62(decimal) gives 36 and 32 respectively in microcontroller registers and when i use type cast function and convert the decimal data into ascii data and then sending it to uc it gives hex o/p so i am confused that how to solve this problem
pls guide me
thanks
satish
(2,832 Views)
So your display from the uc is giving you a hex display instead of the ASCII representation? Are you using VISA to send a string to the uc? Is that string being represented as hex instead of ASCII by the microcontroller? I'm confused about what exactly your setup and problem is...
(2,774 Views)
