interface IHM
how can i create an interface ihm when i click for exemple on a button moves to another interface
(4,500 Views)
asma1234,
I assume by IHM (Interactions homme-machine) you mean HMI (Human-Machine Interface). It's really difficult to the community to give you valuable information if you don't share more about the project you have in your hands. Are you using any hardware? Is this going to run in the PC or in a real-time target? Are you planning on using in the same machine or over the web? Which programming architecture/pattern are you using? There's multiple examples of LabVIEW being used for HMI.
I recommend taking the time to give more details about your application, as well as posting the code you have so far.
(4,472 Views)
i supposed to do an interface for machine test, so i have let's say 22 test on real time and i want to create a window of demarage and 10 seconds later pops up the interface of my machine.
PS: i plan to use the same machine that runs in real time target.
(4,458 Views)
"demarage"?  What does that mean?
(4,450 Views)
hi ,
Download the three vi in the same folder and then run (main.vi ) .
Kudos are welcome .
(4,436 Views)
Hi Emna20,
Can you please provide some more detail on what it is you are trying to do?
Lindsey Nestor
Program Manager, Hardware Services
(4,414 Views)
