VI breaks during cleanup
Hi everyone!
I have a VI which breaks if I clean it up with the embedded solution (hitting Ctrl + U). I have found out that if the VI's name is short enough, then this does not occur. Also, if I remove all broken wires (Ctrl + B), it fixes the VI and cleaning up again results the same error. Can you confirm it please? I have attached the necessary files to reproduce the issue.
I'm using LabVIEW 2018, 64-bit version.
Before
After
(3,187 Views)
Yes, same observation in 2018 32bit. (Only happens if the subVI label is shown.)
(3,175 Views)
Wow!  This is the first I've heard of cleanup breaking things and not being the result of cleanup going nutzo because of a humongous BD.  Congrats on breaking the tool.  😄
Bill
CLD
(Mid-Level minion.)
(3,137 Views)
That's nothing.  Open the attached VI, select just the inner structure, then click cleanup.  It crashes LabVIEW completely.
Works with any two structures, any variable type.  The important thing is 2 nested structures, a comment in the middle, pointed at a terminal, then just select the inner structure for cleanup.
(Already submitted to NI, BTW...)
(3,114 Views)
