intensity graph labling
Is there any way I can customize axis lables on the intensity graph?
For example, I plot an image on the graph. Instead of using the default
indexed numbers(1 to 100 on both axes), I put the physical size of this
image on both axes (i.e., 0 to 1mm and 0 to 2mm on both axes).
This way, I will know the size of the image by looking at the markers.
(2,555 Views)
For each axis, you can set the offset and multiplier to map array indices to real numbers.
(e.g. To have an axis from 0 to 1 with 100 points, set the multiplier to 0.01.)
You can also set the advanced format for the numbers to e.g. "%dmm" or "%.0fmm" if you want the numbers to show as 1mm, 2mm, 3mm, etc. or similar.
You can do all this also with property nodes.
See how far you get. 😄
(2,551 Views)
