intensity chart y-axis
hi, i'm trying to get an intensity chart/graph to have the correct scale on the y-axis. for example on a spectrogram i'd like the y-axis to show the correct frequency. i've seen that it's related to my sampling frequency, but how can i manipulate it. i've searched through numerous examples here and generally on the web, but none seem to scale the y-axis or are very confusing to sus out? any help on understanding on how these things work is much appreciated.
thanks in advance.
(2,684 Views)
Hi
To customize Y scale (or X scale) tou can use a property node
Y scale offset and multiuplier
Offset will set the value for 0 ( in your case will be 0) and multiplier should be Delta F.
Hope it helps
Alipio
"Qod natura non dat, Salmantica non praestat"
(2,677 Views)
brilliant, thats sorted it.
thanks.
(2,664 Views)
