instrument names instead of gpib addresses
     I want to have instrument names coming on the front panel instead of their addresses.If they are connected to PC  a check box should indicate that.How can I go about it?
kiranmayi
(3,378 Views)
(3,373 Views)
So where is the first post then? This is exactly the topic that I was looking for
(3,120 Views)
Since you apparently do not know how links work in web browsers, I'd say you need some basic computer classes before learning and using VISA aliases.
(3,102 Views)
Thnak you for the snarky responds, how profesional of you. But because of your responds, I did not see an underline under "double post" as I learned the first day of HTML school denoting that it would be a hyper link.
(3,082 Views)
Hi erdc,
Maybe this was a default when Mosaic was the most used browser.
Since then a lot has changed and I don't expect links to be underlined. Does your favorite web search or news site still underline all links?
Do you expect underlined thread titles when you go to NI LabVIEW forum?
The link is marked by the text color - and underlined on mouse over for those having problems to note the link…
(3,065 Views)
And the correct wording would be 'response'.
(3,048 Views)
