inserting an array
hi all,
I found the attached VI on the ni homepage. It would perfectly meet my requirements
(filling a database with an array with the possibility to define the number of cols
to be inserted). But i couldn't get it work. I always get the error message 'the number
of columns does not equal the number of parameters'.
Does anyone see what I'm doing wrong?
thank you very much
Simon
(2,791 Views)
Hi Simon,
you want to insert your array in the database in one step, right?
The Bitmap, you attached, shows a way that should work, but uses 1000 steps to fill in the array.
Can you perhaps attach the VI, you mentioned? I seems to be missing...
regards
Peter Weber
NI Germany
(2,791 Views)
