field point read
I want only know if problems exist in my field point configuration:
one PC write and read the field point module and other 4 PCs read the same module at the same time
Thank you for your answer
(2,824 Views)
There should be no problem in connecting from multiple applications to the same FieldPoint bank. The things you should consider when setting up such a system are reported in the following web document
http://digital.ni.com/public.nsf/websearch/8F84131312800F4F86256DC60070EFBD?OpenDocument
AlessioD
(2,824 Views)
