inserting 1D array into another one
hello everyone:
I have complex 1D array of length(3000) and I want to insert another 1D array of length (1200) into the first one starting at index (500) of the first array the output array should with a length (3000) , the problem is that the resulting array with length(4200) not (3000) ?!
(3,607 Views)
Hi ashly,
Why is it a problem when the resulting array contains 4200 elements - after you inserted 1200 elements into your 3000 elements array?
Do you want to insert new elements or do you want to replace elements?
Two options to get a resulting array of 3000 elements:
  1. use ArraySubset to get a subset of 3000 elements from your 4200 elements array
  2. use ReplaceArraySubset instead of InsertIntoArray…
(3,595 Views)
You're doing it wrong.
Show us the code...
(3,595 Views)
I want the two arrays overlapped not concatenated as shown the following figures ni1.png
(3,576 Views)
As GerdW mentioned, it sounds like what you want to do is replace array elements, not insert into array. Replace array elements will write the elements from the smaller array over the elements of the larger array.
(3,569 Views)
Accepted by topic author ASHLY19
The Add simply creates an output of the smallest input size.
The "Insert Into Array" inserts into an array (yes, really 😉).
It's not clear how exactly you want this 'overlap' to happen? Is the Add an attempt, just a test or the requirement?
If you want to add the two arrays, first make sure they are the same size. If addition is the goal, grow the smallest array to the size of the larger one (either calculate the sizes and concatenate the missing data, or use Resize Array), then use Add.
(3,564 Views)
