insert small 2d array into larger 2d array
hi, it is possible to insert a pre exsisting small array into (so it over writes) the data in a larger 2d array at a certian possition (in BOTH definable x and y coordinates)
for example:
2,4
4,7
into
0,0,0,0,1
6,7,2,8,1
6,6,8,3,1
1,3,4,7,9
2,6,5,8,2
to give say:
0,0,0,0,1
6,7,2,8,1
6,{2,4},3,1
1,{4,7},7,9
2,6,5,8,2
or any other position, so you could get it anywhere in that 2d array??
I'm a little stumped, and i don't have any useful VI code to offer.
Message 1 of 8
(3,909 Views)
......or any other position, so you could get it anywhere in that 2d array??
Yes, it's possible (and easy!). You need "Replace Array Subset"
Rod.
Message 2 of 8
(3,902 Views)
Accepted by John Pierson
Like this.....
Message 3 of 8
(3,892 Views)
on oddly i'd tried that on the day i posted the request and it didn't work,
then you suggest it and it works.....
are you a labview wizard?
-chears b.t.w!
Message 4 of 8
(3,844 Views)
No, that would be Altenbach
Message Edited by Cory K on 05-19-2009 10:16 AM
Cory K
Message 5 of 8
(3,835 Views)
Cory K wrote: No, that would be Altenbach
Just curious. How you are comparing this user Rod to our beloved Christian?
Message 6 of 8
(3,801 Views)
It was hardly wizardly (of me) to suggest a single LabVIEW function! I think that the suggestion was made as the function worked afrer I had suggested it but not before. (Isn't that the cardboad cut out progrmmer syndrome)
I read Altenbach's posts and learn.
Message 7 of 8
(3,786 Views)
I called you a wizard because it didn't work before and then it did after you said it should.
Our programming guy here in the uni is dubbed the Labview Wizard because simular things happen.
Message 8 of 8
(3,781 Views)
