insert new value to existing csv file
What version of LabVIEW do you have?
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 11 of 19
(2,053 Views)
Its 2012
Message 12 of 19
(2,046 Views)
@sandy1234 wrote:
Its 2012
Ok, here's the above VI saved to 2012.
Keep in mind, you will need to edit it a bit to make it match the way your data comes in and the format of your spreadsheet timestamps.
Cheers
Message 13 of 19
(2,039 Views)
@sandy1234 wrote:
Its 2012
That snippet was made with 2014.  So you will need to recreate the diagram by hand.  It is a fairly simple diagram, so it shouldn't take you very long and you just might learn something.
Message 14 of 19
(2,035 Views)
Smiley Embarassed
Cheers
Message 15 of 19
(2,026 Views)
Hi ,
yeah I believe it will work but I couldnt get two functions from the palette thatsy anyway I will try it in labview 2014itself... also the last vi is not fetchable as its saying created with later version....Thanks again
Message 16 of 19
(2,023 Views)
You have 2014, but you're using 2012 anyways?
Cheers
Message 17 of 19
(2,007 Views)
Hello James,
2013 is the running system which is in a remote place....also my laptop got crashed and installed 2012 ..currently am doing this in 2012
Message 18 of 19
(2,004 Views)
Accepted by topic author sandy1234
Okay, well it's not a hard VI to mimic, so have at it in whichever version of LabVIEW you would like. Those VIs have been around for a while.
Cheers
Message 19 of 19
(1,996 Views)
