insert new value to existing csv file
I have a CSV file which I created using a totalizer. now I need to insert string values to this by searching the row
Eg:- first column is date so I will search the date and insert comment to it
attached the CSV file
Message 1 of 19
(4,867 Views)
You will need to read the entire file, do your search, add whatever data you need to, and then rewrite the file.
Message 2 of 19
(4,862 Views)
Something like this:
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 3 of 19
(4,846 Views)
HI,
I tried do this but problem server PC is updating this CSV file on a time basis and client PC is displaying and exporting to excel whenever user export
Message 4 of 19
(4,832 Views)
Share you code, please.
Cheers
Message 5 of 19
(4,820 Views)
Hi
Thanks for your attention... please find the attachment
Message 6 of 19
(4,789 Views)
This doesn't really show what your problem is. You should be able to easily implement the code I put above in to this VI you attached.
It's hard to tell what you meant by your statement above, but it sounds like the file is being updated from two different places? So you're having an issue updating the file from the local PC when the server is editing it too?
Cheers
Message 7 of 19
(4,780 Views)
Hi,,
Can you give me the code which you showed I hope it will work
Message 8 of 19
(4,772 Views)
@sandy1234 wrote:
Hi,,
It's a code snippet.  Just copy it and paste it onto your block diagram.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 9 of 19
(4,757 Views)
HI,
Sorry I am not able to retrive the snipet... Its just remains as image
Message 10 of 19
(4,739 Views)
