insert into array not working
My LV version: 8.6 developer suite x86
Hi All,
It seems like the "Insert into Array" based VI would not work when one or more point of entries are empty.  Is there a way to work around this?  Conceptually, it's a very simple thing that I'm not sure how NI people could've missed it.  There must be a way to work around this. Any suggestion?
Message Edited by lavalava on 03-23-2010 02:20 AM
Message 1 of 8
(6,108 Views)
Hi lava,
will you please post a jpg, or a LV8.5 compatible version?
Message 2 of 8
(6,088 Views)
Hi lavalava,
  Basically your usage of that Insert into string Vi is wrong,because to insert into any VI you should define a valid array as innput,but you have wired some undefined array.
Thanks and regards,
srikrishnaNF
Srikrishna
Message 3 of 8
(6,084 Views)
you can go with the build array function
something like this
Guru (CLA)
Message 4 of 8
(6,076 Views)
srikrishnaNF,
I do not see anything wrong with what I'm doing as this problem does not exist for 1D array.  NI have publicly admitted they have had issues with 3D array but not 2D.  My goal is to concantenated some group of 2D arrays in runtime.  In runtime, there are cases when my  some of my inputs will be null and that's fine because the data was already defined, otherwise I would be getting a broken link.
Message 5 of 8
(6,040 Views)
Guruthilak,
I've tried the build array function but the thing is it keeps turnning any group of 2D arrays into 3D which isn't what I want.  I need 2D concatenation output.
Message 6 of 8
(6,037 Views)
Accepted by lavalava
Right-click the Build Array function and select the concatenate inputs option.
Alex Person
NI-RIO Product Support Engineer
Message 7 of 8
(6,035 Views)
xdaf.
Here is 8.5 & 8.2
Message 8 of 8
(6,033 Views)
