insert columns of one array into another
how can one insert columns of an array into another array at every odd place of that array in which insertions are to be made? In short, columns of one array to be inserted into another array bt possibly in between the already initialised array.
(3,003 Views)
So I assume you're atlking about 2D arrays, right?
I'm not too sure that "inserting a column" in the correct wording for what you want, maybe you want to replace some value in a specific column of an array.
Can you give a simple example of what you want, like the 2D array before is :
A - B - C
D - F - G
And after "inserting a column" with  0 - 1 , what do you expect?
Epictetus
Antoine Chalons
(3,001 Views)
thanks for reply.
what basically is the need is i have an array,say
Array 1
1 2 3 4
5 6 7 8
and i have another array,
Array 2
10 11
12 13
the output i want is
1 2 10 3 4 11
5 6 12 7 8 13
see, the array 2 is inserted in array 1 column wise.
(2,996 Views)
Accepted by topic author NainaNarang
here's an example, feel free to ask question if it's not clear for you.
hope it helps
Epictetus
Antoine Chalons
(2,989 Views)
ah...thank you so much..silly of me i shud hv used shift registers from the begining...lost it...
thanks a lot...:)
(2,986 Views)
