Showing results forĀ
Search instead forĀ
Did you mean:Ā
initializing arrays
I need to initialize an array with 64 values. Is there an easy way to do it? It seems quite tedious to select each location and type in a value. The values will not be changeable at run time. Perhaps I am just going about it the wrong way.
Message 1 of 10
(4,910 Views)
Are all values the same?
The "Initialize array" function would be a logical place to start. Have you tried?
If the values are not the same, you must have some formula to derive it based on index. In this case, simply use an autoindexing FOR loop.
Message 2 of 10
(4,908 Views)
Is there a pattern to the values you are putting in?
Message 3 of 10
(4,904 Views)
Oops, sorry. Forgot to mention that the numbers are quite random.
Message 4 of 10
(4,900 Views)
I don't understand the term "quite random"....
Well, you want them to be random or do you want them to be defined based on some complicated formula?
Message 5 of 10
(4,898 Views)
The values appear quite random, meaning that they have no formulaic sequence, but they are not random.
Message 6 of 10
(4,889 Views)
unless you have an algorithm to generate them, you are stuck entering them manually. How is the program supposed to know what to enter?
Message 7 of 10
(4,880 Views)
Try using FOR loop with auto-indexing enabled, as shown in the image attached.
Message 8 of 10
(4,841 Views)
Message 9 of 10
(4,841 Views)
If you find it easier to enter the numbers into a spreadsheet, Read From Spreadsheet File.vi outputs a 1D and/or 2D array.
Message 10 of 10
(4,809 Views)
