initialization
salam
hello I'm looking how to make an init program or reset every midnight that is to say I take the measurement every day
example and I want that this time has 00:00:00,000 all indicators will initialize ...
   AND THANK YOU
Message 1 of 8
(4,547 Views)
Accepted by bilalus
Hi bilalus,
have you ever tried to search the function palette on your own or to read the (context) help?
(One of several possible ways...)
Message 2 of 8
(4,540 Views)
thank you GerdW for this solution, for me it is the first phase but how can I reset all the indicator for a new day
Message 3 of 8
(4,511 Views)
I would look at the day component of the date cluster.  If the day is different then the previously stored day, then you know you have passed midnight.
Message 4 of 8
(4,506 Views)
Hi bilalus,
"how can I reset all the indicator for a new day"
Indicators don't need to be resetted! All they do is show the data that is wired to them.
If you want to show new data for a new day you simply have to wire it...
Message 5 of 8
(4,476 Views)
thank you
 is there a way to clear waveform charts each day
Message 6 of 8
(4,463 Views)
Create a property node for the chart called History Data and write an empty array to that property.
Or create an Invoke Node for the waveform chart that is Reinit to Default Data and execute that.
Message 7 of 8
(4,460 Views)
thanks
Message 8 of 8
(4,436 Views)
