If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
04-14-2010 07:41 AM
Included is part of my main VI.
I am trying to use a bundle to keep track of the failed tests for a pc board. When a test fails, the test number is input into the numeric input of the case structure.
This is how I need this to work: When a test fails, the boolean input is true, and the numeric input is the test number that failed. I am using the property node to add one to the local variable, which keeps a running total of the number of time each test failed. I would like the bundle to update the value of the element, corresponding to the test that failed, but it updates all values, changing all values to 0 except for the test that failed.
I think there is a way to get rid of the inside case structure (and the local variables) and just index the bundle with the top connection.
I guess if I knew how to change the numeric input to a cluster, I could input it into the top of the bundle?
Thanks for the help.
04-14-2010 08:27 AM
04-14-2010 08:29 AM
04-14-2010 08:35 AM
04-14-2010 10:02 AM
Great, it works nice. I guess I don't have enough experience with bundles.
Thanks aeastet for the thorough and prompt reply.
